1987 Ford Taurus Failed smog
SUSAN P
  • 1987 FORD TAURUS
  • 6 CYL
  • 143,000 MILES
My vehicle had passed a smog test just a few hundred miles ago, but then was not driven for about 7 years. Now it is a Gross Polluter. I changed spark plugs, re-set timing, changed oil, cleaned EGR & Oxygen sensor, put fresh fuel in and drove it for a few hundred miles prior to testing. Readings are:
HC NO
15 mph Max112 (285) Max 778 (2198)
25 mph Max 86 (292) Max 717 (2667)
The car runs great, gets good mileage, has lots of power, sounds good, and no codes show up when scanned. Can you tell me what I should check/replace next?
Thank you,
Susan P
Sunday, June 15th, 2008 AT 10:41 AM
PACECLASSA
  • 39 POSTS
Just a guy with a '95 Taurus and not a mechanic, but none answered you so I will give it a shot.
Mine failed emissions and was running "hot" also. I checked thermostat, o2 sensors, MAF sensors, etc. And it was not any of those. I cleaned all the filters, gave it an oil change and ran some engine cleaning stuff through the throttle. Nothing. Replaced all the vacuum hoses (they needed to be replaced badly). It only helped a little.
Replaced the catalytic converters (my car has two) and that solved it.
The stuff up top I did myself and it was cheap. The catalytic converters. A shop and it was a little bit more expensive.
I hope this helps you.
Sunday, June 15th, 2008 AT 3:18 PM
MASTERTECHTIM
  • 4,750 POSTS
With the year of the car I would replace the oxygen sensor. You only have one that controls your air fuel ratio. Get back to us if you need further assistance
Sunday, June 15th, 2008 AT 6:08 PM
PACECLASSA
  • 39 POSTS
Just another guy with a 95 Tarus. Mine also failed. Did the usual, cleaned the fueld injectors, replaced vacuum hoses, o2 sensor, etc. Nothing. It was also the catalytic converters. I think thats your problem.
Saturday, April 10th, 2010 AT 12:51 PM
