1987 Ford Taurus Electric Fan not coming on
150,000 MILES • 6 CYL • FWD • AUTOMATIC
JAMESBG
I took off the cover over the radiitor and found a coumpeter I think. I reached down and took off the plug to the electric fan and gave it 12 volts and it ran for the first time since I had the car. The AC did not work when I bought it and the temp guage hardley moves. The raitor is full with coolent.I took a short trip the other day and turned the switch that sends the heat to the defrost, floor , off, etc,on. The cab started to fill up with steam and fog the window, so I shut it off. I headed for the nearest gas station and left it running and poped the hood. I sprared a little water out of a garden hose on the raditor to cool things down. I was able to open the raditor cap 13 pounds with a small rag over it with no overflow or spray. It was full so I put the cap back on and put a little water in the reserve tank that was not dry.I guess my question is and I am in hot Florida is this normal? I asked another Wrench man and he said the car most likly is OK it just did not get hot enough to tuurn on the fan. He said the temp guage should get up to around 3/4 before it should come on. Do you think this is right? I just don`t want to get broken down some where. Do you think the heater box is shot and that is why the AC does not work? Thanks ahead of time for what you give for a answer.
Apr 2, 2009 at 9:17 AM
JGAROFALO
  • 489 POSTS
You have more than one problem.
The cooling fan should come on when the gauge reaches the 3/4 mark, just like the man said. You should replace the thermostat to get the engine up to proper operating temperature.
The fogging in the car is the result of a leaky heater core. Since you are in hot Florida, you can just bypass it, since you would seldom need or want the heat.
As to the A/C - it is probably not working because the refrigerant has long since leaked out. I would suggest that you convert it to the R-134a refrigerant, and check for leaks. Conversion can be done with a kit that most auto parts stores sell.
Apr 2, 2009 at 10:29 AM
