1987 Ford Taurus
1987 FORD TAURUS
THEBFACTOR26
Engine Mechanical problem
1987 Ford Taurus 6 cyl Front Wheel Drive Automatic
THE CAR DIES GOING DOWN THE ROAD AND WONT START BACK UP UNTIL I PRESS DOWN ON THAT VALVE ON THE FUEL RAIL. THEN IT WILL FIRE RIGHT BACK OFF AND RUN MABIE 30 SECONDS OR UNTIL PRESURE BUILDS BACK UP IN THERE AND I DO IT AGAIN AND IT STARTS RIGHT BACK UP AGAIN. AND SO ON AND SO ON. WHAT COULD BE CAUSEING THAT.
Jul 22, 2008 at 3:09 PM
BLACKOP555
  • 10,386 POSTS
sounds like excessive high fuel pressure if you have to keep releasing it, check the fuel pressure regulator.
you will need a fuel pressure check guage.
Jul 22, 2008 at 4:03 PM
