1973 Ford Taurus 1973 Ford Taurus has no Headlights
12,500 MILES • 6 CYL • 2WD • AUTOMATIC
GALEDIXIE
The Ford Taurus has paarking lights when you turn the switch on. Put when you turn he switch on head lights , they do not come on. I have changed the switch,the turn signal piece,and put new bulbs in. The headlights will come on when I pull the turn signal toward me. They appear to be in brights. But when I push the turn signal away from me, no headlights appear. I have also checked all fuses. Is there anything else that could cause this problem to your knowledge?
May 22, 2010 at 2:24 PM
  • 75,988 POSTS
73 wow! try checking the dimmer switch
May 22, 2010 at 2:31 PM
