2003 Ford Station Wagon starting engine
18,000 MILES • 6 CYL • FWD • AUTOMATIC
JOE PALESCH
I have a 2003 Ford Taurus station wagon. On several occassions I have tried to start the car after driving or even after it has been sitting overnite,but all I get when I turn the key is nothing. No engine light comes on,no cranking,completely dead. I then disconnect the battery cable and wait 30 seconds,re connect the cable and it starts like nothing happened.Is this unique to this car?
Thanks, Joe
Jul 15, 2010 at 1:15 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I would start by having a very close look at the battery terminals, are they corroded at all? how do the battery posts look? any sign of pitting? it may be a case of the terminals not making a good contact, they may look and feel tight, but if they must fit sung and have a good area of contact, if in doubt replace the terminals, i would start here.
Mark (mhpautos)
Jul 15, 2010 at 9:46 AM
JOE PALESCH
I have already changed the contacts terminals .There is no corrosion at all,no sign of pitting either.Could a loose wire somewhere in the engine dept cause a short.
Jul 16, 2010 at 12:56 AM
  • 31,937 POSTS
Check the earth cable where it bolts to the engine, check the main power cable at the starter.
Mark (mhpautos)
Jul 16, 2010 at 1:28 AM
