1999 Ford Station Wagon COOLING FANS INOP
1999 FORD STATION WAGON
10,200 MILES • 6 CYL • FWD • AUTOMATIC
MKELLER088
NO COOLING FANS. aLSO NO HEAT. TEMP GUAGE SHOWS NORMAL, BUT OVERHEATS.
Mar 14, 2009 at 9:20 AM
MERLIN2021
  • 17,250 POSTS
Unplug the fan connector, run wires from the battery to the connector and see if the fan works, if it does, it's possible that one of the two relays in the power distribution center needs replacing, or the ECT, if you are overheating and the gauge shows normaol, temp sending unit is NG. If the car has A/C, turn it on, does the fan come on?
Mar 14, 2009 at 10:06 AM
MKELLER088
Thanks, it was the relay.
Mar 23, 2009 at 8:04 AM
MERLIN2021
  • 17,250 POSTS
Very good.
Mar 24, 2009 at 7:45 AM
