1985 Ford RANGER FUEL PUMP
KJD1984
Engine Mechanical problem
1985 Ford RANGER 6 cyl Four Wheel Drive Automatic
WHERE IS THE FUEL PUMP LOCATED ON THE TRUCK
Nov 17, 2008 at 9:57 AM
DAVE H
  • 13,383 POSTS
the fuel pump is in the fuel tank ..
FUEL PUMP
Removal
Release fuel pressure. See FUEL SYSTEM PRESSURE RELEASE under FUEL SYSTEM. Remove fuel tank. Using fuel tank lock ring wrench, carefully rotate lock ring counterclockwise to release pump. See FUEL TANK LOCK RING WRENCH IDENTIFICATION table. Remove fuel pump from tank.
ApplicationTool No.
RangerT90T-9275-A
Installation
Wipe seal area of tank clean. Position new "O" ring seal onto pump, using grease to hold it in position. Position fuel pump in tank so fuel return hose is not kinked. Install lock ring. DO NOT overtighten pump lock ring, as it may leak. Install fuel tank.
Nov 17, 2008 at 12:25 PM
