1961 Ford Skyliner Horn
45,000 MILES • V8 • 2WD • AUTOMATIC
ACHESON
I removed the 2 hornes to install a overflow tank, I only had room to install 1 horn back. It does not work, do both hornes need to installed to work?
Jun 14, 2010 at 5:46 AM
INTERNETMECHANIC
  • 700 POSTS
I don't have a wiring diagram on that. Maybe you blew a fuse, somewhere. How many wires at the horn connector? If only one, should be voltage, all I could do is backtrack the circuit, without a diagram.
Jun 14, 2010 at 6:34 AM
MIKE H R
  • 3,094 POSTS
This should give you all the wiring diagrams you need for the ford
Sep 18, 2010 at 3:41 AM
