Will only move in reverse
170,850 MILES • 4WD • AUTOMATIC
DTANDIOGORA4
My husband put it in four wheel drive high. After i noticed i changed it to two wheel drive when i was still driving. While i waited at a stop light when the light turned green i tried to drive and it would not drive. When i put it in reverse it reversed with out an issue. When i put it in low gear one it kicks then reverses. I noticed that the transmission fluid was empty so i put one gallon and two quarts of transmission fluid. It still did not want to drive it will only let me reverse. My dash is not giving me any warning issue's. The engine starts with out any issues . It revs up on drive but will not go forward. What would cause this issue?
Jan 23, 2018 at 4:02 AM
  • 55,748 POSTS
The low fluid was a lot one gallon and two quarts can you confirm? Six quarts? If this is true I would scan for codes to see what come up it could be a shaft speeds sensor that is out.
Please run this test and get back to us.
Cheers, Ken
Jan 24, 2018 at 5:33 AM
