whining noise
MARKYBOY
2003 ford ranger, 58,000 miles; 3.0 engine; there is a whining noise coming from the back of the engine. the local ford dealership said there was no problem. i have had a couple of people tell me there is a problem with the distibutor gear thing on the back of the engine making a whining noise. i would like to no what this "thing" is called and does that sound like the problem to you? thanks, mark
Nov 13, 2006 at 6:47 AM
LAYCIE
I had the same problem with my 2003 Taurus. It would whin or chirp. My problem was my Camposition senor located ontop of the oil pump drive assembly was bad. I replaced it and it hasn't done it since. I located the noise by using an automotive stethescope. The sensor on my car was under the air intake assembly where it meets the engine. I hope this helps and I hope your car runs like new again soon. Best of luck!
Dec 19, 2006 at 7:40 AM
LAYCIE
Cam sanchronizer sorry wrong name
Dec 19, 2006 at 8:01 AM
