2002 Ford Ranger Airbag Light Flashing
Suggested Repair
The four-then-six flash pattern is lamp flash code 46, related to the electronic crash sensor. Test the sensor circuits before replacing parts, and follow proper airbag disarm procedures or have a qualified technician do the work. The sticking parking-brake cables are a separate issue; replace only the binding cable if the others still move freely.
Conversation Summary
The owner of a 2002 Ford Ranger reported an airbag light that flashes several times and then stays on, and asked whether it could be reset without a code reader after recent clutch and parking-brake work. The expert explained that the flashes are lamp flash codes and that resetting the light will not help if the fault remains. The owner counted four flashes, a pause, then six flashes. The expert identified code 46 as related to the electronic crash sensor and said the circuits must be tested, with airbag disarm procedures followed to avoid injury. The sticking parking-brake cables were described as a typical separate Ford issue that may allow replacement of only the bad cable.
