trans
BUTCH78
i have a 1999 ranger 4-cylinder 2 wheel drive automatic. it has 104000 miles turned it on and the abs ,check engine,and o/d off light were either blinking or on and the transmission was having a rough time changing gears unless i turned the o/d to the on postion, then it would stay in first gear. i dont know were to start because it all happened at the same time.thanks .
Jul 10, 2007 at 9:57 AM
BUTCH78
1999 ford ranger it has 104000 miles 2.3 liter
Jul 10, 2007 at 10:00 AM
MARKLAURIE
  • 10 POSTS
Make sure you have enough automatic transmission fluid. That usually seems to be the problem when the O/D light blinks on my '97 Ranger. I think I read somewhere that the transmission does not report errors to the ODB so perhaps Ford uses the O/D light flashing as a transmission error code. You'll need a code reader for the engine codes though- but it sounds they may somehow be related to the transmission problem.
Jul 18, 2007 at 2:51 AM
