suspension noise
BESTSAM
1998 ford ranger xlt,2.5 automatic 96000 miles,get a loud noise from right front when i hit speed bumps or pot holes,thought it was coming from upper a arm bushings, sprayed with a lube helped some but not much. shock is good ,front end seems very tight,no swaying or pulling to either side,any thoughts would be great.
Sep 13, 2007 at 2:35 PM
BMRFIXIT
  • 19,053 POSTS
[quote:46c9f62587="bestsam"]1998 ford ranger xlt,2.5 automatic 96000 miles,get a loud noise from right front when i hit speed bumps or pot holes,thought it was coming from upper a arm bushings, sprayed with a lube helped some but not much. shock is good ,front end seems very tight,no swaying or pulling to either side,any thoughts would be great.[/quote:46c9f62587]
hi there
what kind of noise?
check under the truck passenger side .
make sure e brake is on car in park and engine off
look for a bushing almost under the passenger seat
look for a bar from the front end going back to the fram of the truk at the fram side you can see nut at that bar and some bushing . i thing they call them radius arm bushings
check them
good luck
Sep 13, 2007 at 3:14 PM
