front end noise?
DHILL88
2002 Ranger, 62,000 miles. 32k miles when I bought it, and had an unusual noise in the (I think) front end. Sounds almost like a universal joint popping noise. Here's the really odd thing--it doesn't do it in cold weather. Only when it's warm. Seems to be coming from the steering, but really it's just hard to tell. Something you can almost feel as much as hear. Annoying, but doesn't seem to be getting any worse. Ideas? Thanks.
Nov 10, 2010 at 10:47 PM
WRENCHTECH
  • 20,760 POSTS
Based on your description, it's difficult to pinpoint the exact cause of the noise
Suspension Components:
Steering Components:
Universal Joints:
Heat-Related Expansion:
Nov 10, 2010 at 10:56 PM
JIMBIE
dhill88, did you ever figure this out? I also have a 2002 Ranger that has what you describe perfecty. It's been going on for three years. I have had it in the shop three times and was told nothing was found.
Jul 9, 2011 at 8:09 AM
DHILL88
Local Ford dealer thinks it's ball joints and tie rod ends, as well as a loose shock. Want's $1,100 to repair, found same repair at another shop for $650, haven't done it yet so I don't know if that will fix it. Tried greasing myself (no fittings, just sprayed white lithium) with some success but not total. Hope this helps.
Jul 9, 2011 at 8:24 AM
JIMBIE
The last time I had it in they told me there was a little wear in the upper ball joints but they didn't need changed yet. I had them do it anyway. That seamed to help some for a while, but it's as bad as ever. I've checked the tie rod ends myself and they are OK. They were changed several years ago, prior to this starting. Strangest part about all this is that the ride and steering is unaffected. I've replaced the front shocks also. I guess I'll keep stracting my head for a while. LOL
Jul 10, 2011 at 6:03 AM
