Stuttering while changing gears.
TUBKILLER7
1999 Ford Ranger 133,000 miles. I drive my truck everyday, and sometimes when i hit about 30 mph it starts to stutter in between gears. Would that be the transmission giving out?
Nov 15, 2007 at 5:12 PM
TOBYU
  • 89 POSTS
Probably fluid shutter...
The torque converter caused the rumble strip effect.
The best fix for TCC shudder is a pan drop and fluid/filter change.....but a flush will do it as will some friction modifyer additives made to solve the shudder problem.
Neither is as good as a pan drop and filter/fluid change. Most fords have a converter drain plug too. So you CAN get ALL of the fluid out which is what many flush shops preach about....
Apr 16, 2019 at 4:57 AM
TUBKILLER7
Thanks, I will get that checked on
