stuck oil filter-will not come off?
FORD RANGER
CAMERONCETTO
94 Ranger 2.3 L 5 speed manual 152,677 mi Actually a generic question. I cannot get my oil filter off the engine. I changed the oil 2000 mi ago and the filter went right on w/no problems. I've tried the screwdriver thru the middle trick, the crush it til it turns trick and the hammer a screwdriver on the lip in the off direction tricks. I'm fresh out. HELP!! Can't afford to have it towed, much less a mechanic.
Aug 1, 2007 at 10:50 AM
SERVICE WRITER
  • 9,123 POSTS
Removing a stuck oil filter can be frustrating, but there are a few methods you can try to loosen it. Keep in mind that you might need to apply a bit of force, so be cautious and patient during the process. Here are some additional tricks you can attempt:
Oil Filter Wrench: Purchase or borrow an oil filter wrench designed to grip and turn the filter securely. Make sure you choose the appropriate size for your oil filter. These wrenches provide extra leverage and make it easier to turn the filter.
Rubber Strap Wrench: A rubber strap wrench can be effective in removing stuck oil filters. Wrap the strap around the filter and use it to get a better grip while turning.
Heat and Cooling Method: Some people have had success using temperature changes to loosen the filter. Run the engine for a few minutes to warm up the oil, which may help expand the metal and make it easier to remove. Then, use a bag of ice or a cold compress to cool the filter. The temperature change can cause the metal to contract slightly, which might help loosen the filter.
Puncture Method: Be cautious with this method as it can be messy. Use a screwdriver or a sharp tool to puncture a hole in the oil filter. This will release some pressure and potentially allow air to enter, which can break the seal and make it easier to remove.
Filter Claw Tool: This is a specialized tool designed to grip the oil filter firmly and provide extra leverage for removal. You can find these tools at auto parts stores.
Oil Filter Pliers: Oil filter pliers are another specialized tool that can provide a strong grip on the filter and assist in turning it.
Remember to wear gloves and be prepared for oil to spill when you finally manage to break the filter loose. Once the filter is removed, ensure that the rubber gasket from the old filter did not stick to the engine surface. If it did, remove it before installing the new filter.
Aug 3, 2007 at 12:58 PM
