1994 Ford Ranger with 162k miles. 2.3L 4 Cylinder - Had a heat wave up here in Michigan and that's when I noticed a problem and later the pattern: truck will turn over but not kick on if the engine is too warm (too warm means sitting in 90-degree heat for more than 3 hours or driving for more than 25 minutes). Just changed the plugs and wires. Electrical system seems to be running great. Also - if I try and try and try with no success, and I get out of the truck and give it a "15-minute break", then try again - it works. This one is definitely a problem for Dr. House...
Jul 13, 2007 at 8:11 AM
