ranger help
AMTM
I have a 1990 ford ranger with a 4 cly.It has no spark and I was wondering if you tell me how to test the crank sensor with a dvm.and any other tests that I should proform.thank you.
Apr 28, 2006 at 8:57 AM
THERASPER
  • 11 POSTS
I'd suggest getting a repair that has a diagnostic tree. It will lead you step by step through what to check, and how to check it... A few hit and miss comments here won't take you near as far as the patterned search of a good diagnostic method. It is then as simple as "check so-and-so... this is how you check it... is it good or bad? it's good? ..then step two..." and so on, to an end.
Best of luck in your repair.
Apr 28, 2006 at 5:50 PM
