Blend door actuator not working properly
1998 FORD RANGER
01TIGHE
I have a 2.5L that only blows hot air the control dial has no effect on the temperature. Can you help?
Sep 21, 2006 at 4:06 AM
LOSTONE
I have a 1996 Ranger with similar problem. My temperature switch seems to have only two settings, cold and hot. It does not matter what the selector knob is set to (ie. non-AC setting), if I turn the temperature switch to the blue area (cold), I get AC air (not just cold air from outside, but AC air). Recently, it has started acting even goofier. The only way to get AC air is in the "Max AC" setting. All other settings give me heat, regardless of the temperature switches setting. Have you had any luck figuring out your problem? It might help me figure out what is wrong with my truck.
Oct 20, 2006 at 6:03 PM
CMARMCGHEE
This is a problem with your temperature blend door actuator is going out. Here is a guide and diagrams below of what you need to do to fix the problem:
Cheers
Oct 25, 2006 at 10:19 AM
TODD
  • 5 POSTS
I have a 1998 Ranger with the same problem.
I am attempting to fix mine this way. Almost got it, just needs a little tweaking as to where to put the pin.
Todd
Nov 27, 2006 at 4:32 AM
FREEDOM33
Thank you so much for the step by step. One final question, can I drive this vehicle until I find the time to attempt to fix it?
Nov 30, 2006 at 3:58 PM
TODD
  • 5 POSTS
Sure, drive away. Mine has been unplugged while I have been trying to fix it (still trying to find the perfect place for the "pin" and no time to do it). Since that piece is broke on the blend door it does not matter whether or the actuator it is plugged in or not. Everything in mine is the same as it would be if it were plugged in.
Nov 30, 2006 at 11:24 PM
DANIEL CONNIFF
Temperature control does not work in my my truck listed above XLT. Heat stays on despite turning to the cool setting?
Oct 2, 2018 at 12:30 PM (Merged)
WRENCHTECH
  • 20,761 POSTS
The temperature is controlled by the use of an air mix door that is operated by an electric motor/actuator. This door can be jammed or the actuator can be inoperative or have stripped plastic gears internally.
