Problem with the clutch on a 1995 Ford Ranger XLT
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the noise evaluated with the clutch service history available. Ask what findings distinguish the release mechanism, pilot bearing and other possible sources before authorizing disassembly.
Guidance references and applicability
Source: This question and its visible discussion, including any clearly labeled editorial corrections. Owner reports are distinguished from other participants' experiences. Follow-up guidance is not a confirmed diagnosis.
Discussion summary
A 1995 Ranger developed a grinding noise with the clutch pedal depressed after earlier clutch work. The owner asked whether a pilot bearing could cause the symptom.
Reported outcome: No inspection findings or completed repair were reported.
The reply's claims about pilot-bearing damage were not confirmed on this truck. Pedal-dependent noise alone did not identify a failed bearing.
