Neutral Safety Switch
SPAZZMATIC
  • FORD RANGER
2003 Ford Ranger XLT 45000 miles. I am about to put an alarm on my Ranger. The alarm has remote start on it and I have a manual transmission. The question I have is does this truck have a Neutral Safety Switch on it? If it does I can just tap into that and have the remote start work just fine otherwise I am going have to put a pin in each gear.
Friday, April 13th, 2007 AT 5:08 PM
TAURUSWHEEL
  • 718 POSTS
Your clutch interlock does that job, you must push the clutch to start in any position, neutral included? I know my 87 Taurus was set up that way, depressed clutch always to start.
Friday, April 13th, 2007 AT 6:01 PM
MERLIN2021
  • 17,250 POSTS
As far as I know it is Illegal to put a remote start on a standard shift. If it starts with no driver and moves. You will own the result!
Friday, April 13th, 2007 AT 6:09 PM
TAURUSWHEEL
  • 718 POSTS
Good point, sounds reasonable to me. Something goes awry the parking brake, if remembered to be applied wouldn't hold it back, never entertained the idea of one on my car.
Friday, April 13th, 2007 AT 8:11 PM
