1996 Ford Ranger Timing Marks
CARLWAYNE
I have a '96 Ford Ranger, 2.3L, I need to know what am I suppose to go by to set the timing, the diamond or the groove. Thank you.
Jun 15, 2007 at 3:27 PM
98RANGERXLT
  • 301 POSTS
Open the hood and look at the emissions label or the vaccum line label on one of those it says either timing not adjustable or timing adjustable if it says not abjustablr then the computer does it
Jun 17, 2007 at 10:04 AM
Suggested Repair
Check the underhood emissions label or vacuum-line label to see whether timing is adjustable. If the label says timing is not adjustable, the computer controls timing and it should not be set manually.
Conversation Summary
The owner of a 1996 Ford Ranger 2.3L asked whether ignition timing should be set using the diamond or the groove mark. The expert advised checking the emissions label or vacuum-line label under the hood, which states whether timing is adjustable. If it says not adjustable, the computer controls timing.
