location of obd II connector
FORD RANGER
VICTOR1244
Could you please tell me the location of the obdII connector on a '96 Ranger P.U. Thank you
Nov 2, 2007 at 2:14 PM
MERLIN2021
  • 17,250 POSTS
All OBDII connectors are on the drivers side under the dash, on Fords usually on the gas pedal side! Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Nov 3, 2007 at 12:08 AM
VICTOR1244
Thank you for your answer, But I still can't find the connector. It's not on either side of the steering wheel.
I have come across the flasher relay, but not the OBD II connector. Is it tucked in under the dash or is it mounted somewhere? Victor1244
Nov 6, 2007 at 9:44 AM
98RANGERXLT
  • 301 POSTS
Okay if you look at the hood release look about an inch to your left you will see a cover same color as the dash remove that cover and its right there
Nov 8, 2007 at 1:04 PM
VICTOR1244
Thank you very much. I will check it out first thing in the morning. Sorry to be so needy. Victor
Nov 8, 2007 at 1:20 PM
VICTOR1244
I found it. Thank you very much.
Nov 9, 2007 at 11:51 PM
98RANGERXLT
  • 301 POSTS
Your welcome
Nov 10, 2007 at 7:59 AM
HALLER38
Where is the OBD2 connector located in a ford ranger?
Feb 3, 2019 at 12:46 AM (Merged)
obd 1 connector is under the hood, left side.
HALLER38
Thanks now I just my other question answered and ill be set I appreciate it
