ignition cylinder lock wont remove please help
VAINZANE
I lost the last key to my 97 ford ranger. So I drilled through the key hole like I was told but the drill bit broke off inside. So I drilled a bigger hole that the small pin goes through to make it big enough to pull the pin out. I pulled the pin that is supposed to be the only thing that holds into place out. It will giggle but wont move but about a 1/4 inch out what should I do? Please help
Aug 26, 2007 at 12:43 AM
SERVICE WRITER
  • 9,123 POSTS
https://images.2carpros.com/forum/automotive_pictures/30961_st1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_st2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_st3_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_stpic_1.jpg
Aug 26, 2007 at 2:40 AM
VAINZANE
thanks for your help but that not my problem i cant drill any further becuse my drill bit broke off inside cant get past it. i took out the pin. what i need to know is how to pull it out without being able to drill any further. keep in mind that the pin on bottom is no longer there. !!!!! is there anything else that could be holding it in!!!!! becuse i getting so mad i thinking of tieing an electric wench to it. it will giggel but wont come out mabe i'm not strong enough?
I thank you for your help. man i at the end of it with this peice of ....
Aug 26, 2007 at 6:11 AM
SERVICE WRITER
  • 9,123 POSTS
You might be able to extract the but with a coping saw blade. You gring the back side of the blade to a gradual point.
Aug 26, 2007 at 10:33 PM
