1987 Ford Ranger No Power Under Hood
MATT_522000
  • 29 POSTS
ok i have a 87 ranger with a 2.9 and it will turn over but has no juice to anything under the hood. everything inside of the cab works just nothign under the hood and icant figure this one out please help!!!!!!!!!!!!!!!!!!!! :shock:
Mar 14, 2006 at 4:22 AM
PEPPERMRJ
  • 1,158 POSTS
I vote for the TFI module.
Good luck and let us know. :)
Mar 14, 2006 at 1:22 PM
MATT_522000
  • 29 POSTS
i already replaced that and still nothing theres no power to anything under the hood but i can bypass it and turn it over from the selonoid on the fender but then still wont have any power going to anythign
Mar 15, 2006 at 4:16 AM
PEPPERMRJ
  • 1,158 POSTS
Could be an ignition switch or the solenoid under the hood. Check all the fuses also.
Good hunting. :)
Mar 15, 2006 at 7:46 AM
MATT_522000
  • 29 POSTS
fuses are fine will replace ignition switch. thanks for the help ill check it and see
thanks again :D
Mar 16, 2006 at 5:52 AM
Suggested Repair
Replace the ignition switch and inspect the under-hood starter solenoid. The fuses were reported good, and the TFI module was already replaced without restoring under-hood power.
Conversation Summary
The owner of a 1987 Ford Ranger 2.9 said the engine would turn over but nothing under the hood had power, while cab accessories worked. Cranking from the fender solenoid still left no under-hood power. After the TFI module was replaced with no change, the expert suggested the ignition switch or under-hood solenoid and advised checking fuses. The owner confirmed the fuses were fine and planned to replace the ignition switch.
