1998 Ford Ranger Headlight Switch Not Lit
98RANGERXLT
  • 301 POSTS
I have a 1998 Ford ranger and the headligt switch lights up I would like to know why it is not lighting up anymore and is it a fuse switch etc tanks :?
May 30, 2007 at 4:49 PM
RUDPRO
  • 224 POSTS
Try looking behind the dashboard from underneath to see if you can access the bulb. If not, you may have to take the dashboard apart to get at it and replace it.
May 30, 2007 at 5:30 PM
98RANGERXLT
  • 301 POSTS
How many bulbs are there and what kind are they
May 31, 2007 at 12:29 PM
98RANGERXLT
  • 301 POSTS
Do i just have to pull the bottom panel off or the whole dashboard?
Jun 1, 2007 at 12:31 PM
RUDPRO
  • 224 POSTS
You have to remove the instrument panel to get at the headlight switch. I not sure if the switch has to be changed or if there is a bulb behind it. You'll have to look at it when you take it apart. Private message me with your e-mail address and I can send you an exploded view of how to take it apart.
Jun 2, 2007 at 11:29 AM
Suggested Repair
Remove the instrument panel to access the headlight switch, then inspect whether the illumination bulb or the switch itself needs replacement.
Conversation Summary
The owner of a 1998 Ford Ranger says the headlight switch illumination no longer lights and asks whether a fuse or the switch is at fault. An expert advises removing the instrument panel to reach the switch and checking whether a bulb behind it or the switch itself needs replacement.
