I have a 1990 ford ranger 4.0 liter engine. It will leak gasoline every so often from the engine area. It does not do this all the time. I just replaced 2 fuel injectors and all was fine for about one week. Then it started leaking a good amount of gas from the engine again. Any ideas what this could be. It has not leaked since then and that was a week ago? Could it be the fuel regulator or the other injectors? When it leaks there is a lot of fuel coming out and onto the ground under the engine. I have not been able to get it to do this again, any ideas?
Mar 26, 2007 at 6:37 AM
