fuel leak 1990 ford ranger, 94000 4.o liter
1990 FORD RANGER
DANTINAK
I have a 1990 ford ranger 4.0 liter engine. It will leak gasoline every so often from the engine area. It does not do this all the time. I just replaced 2 fuel injectors and all was fine for about one week. Then it started leaking a good amount of gas from the engine again. Any ideas what this could be. It has not leaked since then and that was a week ago? Could it be the fuel regulator or the other injectors? When it leaks there is a lot of fuel coming out and onto the ground under the engine. I have not been able to get it to do this again, any ideas?
Mar 26, 2007 at 1:37 PM
MERLIN2021
  • CERTIFIED EXPERT
  • 17,250 POSTS
If it won't do it again that' good! right! Any codes?
Mar 26, 2007 at 4:47 PM
DANTINAK
No codes. My only concern is the next time it could cause a fire. As of right now the only answer seems to be replace the fuel regulator on the fuel arm and keep your fingers crossed. Do you have any other ideas?
Mar 26, 2007 at 4:56 PM
DJM76@JUNO.COM
  • 11 POSTS
It could be the schrader valve on the fuel rail that was leaking on mine I replaced it and no more leak.
May 19, 2014 at 7:00 AM
