Ford Ranger Clutch problem
MAYHEW75
I have a 2002 ford ranger man. transmission - The clutch would not engage this morning, The fluid was gone, so I replaced, and bled the system. figured this would do the trick. (It had been sloppy for a few days.) Upon starting the car, I cannot get the car into gear. was the system bled wrong? Should I try and repeat all steps?
Nov 20, 2007 at 3:37 AM
AUTOPRO
  • 45 POSTS
These clutches bleed themselves but the fact that the fluid was gone means the clutch master or secondary cylinder is leaking so I would use a flashlight and look under the dash at the rear of the clutch master and at the lowest part of the bell housing of the transmission and look for fluid. I have seen the secondary cylinder leaking cause this problem FYI.
Here are two video to help us see what's going on and how to fix it.
this video who the job being done on a similar car the procedure is the same.
https://youtu.be/JpzefqEeVGE?si=swN61q1MPyivB1cv
This guide may help as well
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
Please go over these guides and get back to us.
Nov 20, 2007 at 11:20 AM
