bucking and hesitating and shuddering
WILLGRIFFIN2
Had engine code on for o2 sensor let it stay for a while but had it fixed. bucking became real bad after that. it started only under heavy acceleration but it has become where it bucks and hesitates every time you give it gas. i replaced o2 sensors, fuel filter, plugs, and cleaned the Mass air flow sensor with carb cleaner, but not the wires. i ran a bottle of Lucas fuel stabilizer and injector cleaner through and the truck ran like a dream without a single stumble, so i dont think it is the wires. as soon as that tank of gas went through however the bucking came back and a lot harder, it not shudders and runs at inconsistent RPMS at idle, and the exhaust pipe all the way along the truck bounces pretty bad but there is not clamps missing or mounts fallen off for exhaust line. no engine light on and nothing is showing up when i take it to Autozone Please somebody help me, im about to push truck off bridge.
Jun 26, 2007 at 9:12 AM
98RANGERXLT
  • 301 POSTS
Does this happen after you fill up?
Jun 26, 2007 at 2:38 PM
WILLGRIFFIN2
it happens all the time and doesnt matter if tank is full or near empty.
Jun 28, 2007 at 12:32 AM
98RANGERXLT
  • 301 POSTS
It may be your fuel pump going out or the sock on the end may be plugged here's a guide to help check the pressure.
and if bad this guide will help walk you through the repair.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Jun 28, 2007 at 12:37 PM
WILLGRIFFIN2
if so why would the injector fluid help out the running condition of the truck. if it indeed is the fuel pump how do you check it and what does it cost to replace. thanks for all your help and keep it coming please.
Jun 29, 2007 at 1:42 PM
98RANGERXLT
  • 301 POSTS
Next time your tank is almost empty drop the tank and unscrew where the fuel pump goes and pull it out check the sock on the end of the fuel pump then take it to a trusty mech and have them check the fuel pump
Jun 29, 2007 at 5:36 PM
WILLGRIFFIN2
I got a new pump today and installed it the truck has never run better. Thanks for your help I love this site.
Jun 30, 2007 at 4:48 AM
98RANGERXLT
  • 301 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Jun 30, 2007 at 9:30 AM
