2000 Ford Ranger Fusible Link Location
NUNAVUT
  • 15 POSTS
Hi everyone, anybody know where the fusable links are on this vehicle. Found one by the battery and fuse box but cant find the other one. Im talking about the link that is about 1" L by 1/2" w.
Sep 11, 2006 at 4:25 AM
NOS
  • 320 POSTS
did you check in the fuse box under the hood it sounds like the one you talking about has two copper ends with holes one end goes to battery feed side and the other feeds the fuse box.am i on the right track?PS also check by the starter solinoid there is usualy several there connected to the pos side battery side of the solenoid.
Sep 11, 2006 at 4:31 PM
Suggested Repair
Check the under-hood fuse box for the fusible link with two copper ends that connects the battery feed to the fuse box. Also inspect the starter solenoid positive battery side, where several fusible links are usually attached.
Conversation Summary
The owner of a 2000 Ford Ranger found one fusible link near the battery and fuse box but could not locate another about 1 inch long by 1/2 inch wide. The expert advised checking the under-hood fuse box for the copper-ended link between the battery feed and fuse box, and checking the starter solenoid positive side where several links are typically connected.
