Clutch / throwout repair
92SHOINPA
  • FORD RANGER
97 Ranger, 90,000 miles
Trans fluid replaced every couple of years, most recently a few months ago. Always use Mobil1 atf.
This truck is getting progressively harder to shift. Getting into first gear is a real challenge, no grinding, but very hard to engage. 2nd is much easier, but still somewhat difficult. 3, 4, 5 are all just slightly hard to shift into. Very recently developed, reverse can not be engaged (without grinding) unless you shut off the engine first. All gears engage smooth as butter when the engine is off.
I am assuming that this all points to a clutch replacement, correct? If it is the clutch, what should I do about the TOB / slave cylinder. Of course I would replace the TOB. What about the slave cyl? Should it necessarily be replaced too?
Thursday, November 15th, 2007 AT 7:45 AM
  • 31,937 POSTS
Hi there,
if at all concerned change the slave cylinder while you do the clutch O/Haul also machine the fly wheel and replace the spigot bearing. For the little extra it will cost you will have the piece of mind that its new and it won't cause a problem down the track.
Mark (mhpautos)
Thursday, November 15th, 2007 AT 8:25 PM
