After plug replacment engine shuts off at first idle/start.
98FORDRANGER
98 Ford Ranger 128000 miles 5 speed manual. I recently preformed a tune up consisting of plug replacement, plug wires. I then developed the truck shuts off when you idle at stop lights, stop signs. This will go away after the truck warms up. The check engine light came on and displayed a code of P0171 system too lean (bank 1) which references the following:
Plugs
Plug Wires
O2 Sensors (Both replaced)
Mass Flow Intake
The only thing I haven't checked for is vacuum hose leaks. (Safest way to do this?)
Any help would be greatly appreciated.
Thanks,
98fordranger guy
Nov 27, 2007 at 2:38 PM
FISHERMAN
  • 937 POSTS
[quote:700d08bdd3="98fordranger"]98 Ford Ranger 128000 miles 5 speed manual. I recently preformed a tune up consisting of plug replacement, plug wires. I then developed the truck shuts off when you idle at stop lights, stop signs. This will go away after the truck warms up. The check engine light came on and displayed a code of P0171 system too lean (bank 1) which references the following:
Plugs
Plug Wires
Mass Flow Intake
Thanks,
98fordranger guy[/quote:700d08bdd3]
Hello !!
looks to me like the Mass air flow sensor its not working right (not sensing the right amount of air entering the engine and that causes a lean system)
that could be related to the work you do to the engine.. and you`re probably right: could be a vacuum leak!
check the schematic on the hood and check the hoses one by one (you should be able to hear the 'noise" of a vacuum hose disconnected...
good Luck and let us know!
Nov 27, 2007 at 4:18 PM
FSTRANGER302
  • 117 POSTS
[quote:2ccabf7cb2="98fordranger"]98 Ford Ranger 128000 miles 5 speed manual. I recently preformed a tune up consisting of plug replacement, plug wires. I then developed the truck shuts off when you idle at stop lights, stop signs. This will go away after the truck warms up. The check engine light came on and displayed a code of P0171 system too lean (bank 1) which references the following:
Plugs
Plug Wires
Mass Flow Intake
Thanks,
98fordranger guy[/quote:2ccabf7cb2]hello, make sure your snorkel for the air filter at the throttle body is tight will cause a vacum leak and stalling problems let me know if this helps. pat
Dec 5, 2007 at 4:03 AM
