No codes. 1st half of throttle responds correctly, 2nd half feels as if engine is governed, tach shows no sign of slippage. feels as if pulling a load, with empty box. RPM seem low when placed into next higher gear. enging runs smooth at idle/ through out range.
thinking one of the sensors that feed the PCM, which in turn supplies timing.
have changed; fuel & air filters, plugs, wires, coils, running injector cleaner-2nd tank
any idea's welcome, thx.
2.3L, x-cab, 2wh-dr, 5-sp/manual, apx.120k
Nov 28, 2007 at 7:02 PM
