95 ford ranger with dtc p0402,p1401,p1443
BDKFAM
95 ford ranger 4 cyl with 265,596 miles. with dtc p0402,p1401,p1443. what are the codes for?what needs to be replaced?my truck needs to be smoged, but cant until i fix the problems. thanks for your help.
Apr 11, 2007 at 8:32 AM
MERLIN2021
  • 17,250 POSTS
P1443 Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault
P1401 Differential Pressure Feedback Electronic Sensor circuit High Voltage
P0402 If the third digit in your VIN is a "1", your DTC means Infl Rest System Indicator Circuit Malf.
If the third digit is a "2", the DTC means Temp. Gage Data Out of Range
Can't tell ya on the 402!
1443 Means there is a leak in the evap system...Ford uses a smoke machine to test the system...
Apr 12, 2007 at 9:36 AM
BDKFAM
[quote:4745af6912="bdkfam"]95 ford ranger 4 cyl with 265,596 miles. with dtc p0402,p1401,p1443. What are the codes for?what needs to be replaced? How can I fix this my self? My truck needs to be smoged, but cant until i fix the problems. Thanks for your help.[/quote:4745af6912]
Apr 12, 2007 at 10:39 AM
