2009 Ford Ranger 2009 Ford Ranger IAT: att Razmatz
15,000 MILES • 6 CYL • 4WD • AUTOMATIC
OTTODOG10
Thank you Razmatz for the diagram , that does tell me that the IAT is combined with the mass air sensor, but to connect the module I have to know which wire is the ground and which is the signal wire. If you can help me I would be again greatfull , because you have already sent me in the right direction and I thank you for that.
Sep 9, 2010 at 2:20 PM
  • 75,988 POSTS
The green and white wire is the signal return path and the feed is the violet and gray
Sep 9, 2010 at 8:46 PM
