2007 Ford Ranger Left Turn Signal & Brake Light
2007 FORD RANGER
26,000 MILES • 4 CYL • 2WD • AUTOMATIC
MJSTOREY
My left hand turn signal and break lights stoped working. When L/H turn signal are actuated the indication on dashboard is that they blink twice as fast than the right. I checked all fuses and bulbs all are good.
I purchased a flasher relay, but I can't find the location on the truck.
Can you help?
Thanks,
Mike
May 4, 2010 at 4:13 AM
  • 110,244 POSTS
Mike, replace the rear brake light bulb and the problem will be solved.
Let me know if it helps.
May 11, 2010 at 6:16 AM
