2007 Ford Ranger leaking water
21,310 MILES • 6 CYL • 2WD • MANUAL
GEEDUB8
is it worrysome that im leaking water from just insid and behind my passenger front tire? i think its just a.c. what are the possible problems? thanx, geedub8
Jun 15, 2009 at 12:07 PM
  • 31,937 POSTS
Hi there,
This should just be the A/C drain tube, the A/C will be humidify the air as it operates and the moisture ids drained off via the drain tube, if it is colorless & orderless it will be the A/C drain.
mark (mhpautos)
Jun 15, 2009 at 12:30 PM
