2006 Ford Ranger WHERES the fuel filter located
2006 FORD RANGER
87,000 MILES • 6 CYL • 4WD • AUTOMATIC
AZWAYNE
when i drive no problem but when i come to a stop the truck begins too shake rattle and roll and then quits running.ican start it up and take off it it will be fine until i stop again..help azwayne thankyou
Jun 4, 2010 at 8:23 PM
BMRFIXIT
  • 19,053 POSTS
idle problem
open hood and check for vacuum leaks
remove and clean IAC valve
if have check engine light on ,have it scanned for codes
hold foot on gas (raising the RPM )does this help and if so and no vacuum leaks suspect IAC valve
Jun 4, 2010 at 10:36 PM
