I noticed the left rear brake was hot and smoking
68,000 MILES • 4 CYL • 2WD • MANUAL
WYNCRTR
After driving my truck home from the shop I noticed the left rear brake was hot and smoking. The shop did not do anything to the rear brake shoes they only installed new rotors and disc brake pads on the front. I called a reputable mechanic friend and he said the shop mechanic may have failed to reset the proportion valve and there is too much pressure going to the rear brake causing it to be rubbing the drum and getting hot. I noticed after checking rear brake I need them can you help?
Feb 12, 2009 at 1:00 PM
Here are guides that will help with this:
https://www.2carpros.com/articles/how-to-replace-rear-brake-shoes-and-drums
https://www.youtube.com/watch?v=-Ts8SRUxRc8
Below is the process from the manual that will help with this. Please let us know if you need more help or other info.
Thanks
Apr 8, 2021 at 12:08 PM
