2005 Ford Ranger tail light
125,000 MILES • 4 CYL • 2WD • MANUAL
1CINDY
rear tail light signal light comes on brake light comes on but when turning on the front and rear lights the light does not come on Y
Feb 19, 2010 at 5:38 AM
HMAC300
  • 48,601 POSTS
check to see if you have a good grond on the back, you probably don't causing it to not work. also check to make sure power is coming to the tail light when the lights are on.
Feb 20, 2010 at 12:39 AM
