Plenty of fuel. Plenty of spark. Low compression. Misfire on number 4, 5, 6. Runs good cold until it warms up.
Thursday, January 21st, 2010 AT 3:53 PM
TOOOMANYTOYS
MECHANIC
If all the cylinders on that bank have low compression. I would do a wet compression test. This is done by adding a small amount of oil into the cylinders with low compression. If the compression goes up then you have a piston to bore issue. If it stays the same you may have a valve sealing issue.
