2005 Ford Ranger Noise when driving
2005 FORD RANGER
57,000 MILES • 6 CYL • 4WD • AUTOMATIC
SOTHUNTER
I recently noticed a Sound when driving its more noticable at speeds of 25 to 35 mph. Its noticable at highway speeds too but less pronounced. It sounds Like a rur rur sound I have been using the four wheel drive because of Bad snowy weather the car was fine then then noise just began. It makes the same sound in and out of four wheel drive.I drove the car over different pavement surfaces and the sound remains the same. I swerve back and forth to see if it is wheel bearings the sound does not change. Any Ideas?
Feb 28, 2010 at 1:06 AM
  • 110,240 POSTS
Have you checked the fluid in the front differential and the transfer case?
Mar 1, 2010 at 2:47 AM
