Only fill up at a gas station where you dont see a tanker filling the tank. If so avoid that place for atleast an hour to keep water and junk out of it.
Nexzt would be to use fuel additives often to keep gas from going bad and use the gas up fast so it doenst go bad and varnish and cause the filter to gum up.
But all that precautions it will still go bad. But its a cheap and easy fix. Way cheaper then all the addtives.
SPONSORED LINKS
Sunday, August 23rd, 2009 AT 4:22 PM
