2005 Ford Ranger engine dies
SAMSONIRONWORKS
  • 2005 FORD RANGER
  • 6 CYL
  • 92,000 MILES
Driving normal on highway. Engine dies. No problem with vehicle until now. Has gas (1/2 tank) and changed fuel filter. Engine turns over but will not start. Any suggestions? Checked the spring load gas port on top of engine. Sprays gas.
help?
Wednesday, June 17th, 2009 AT 8:26 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Check for spark pull plug wire ground to block
Let me know
Wednesday, June 17th, 2009 AT 10:17 AM
SAMSONIRONWORKS
Definitely getting spark (elec) to the plugs
any other things?
Wednesday, June 17th, 2009 AT 7:14 PM
DOCFIXIT
  • 18,828 POSTS
Spray some carb cleaner into throttle body does it fire up?
Thursday, June 18th, 2009 AT 10:11 AM
EDINGMAN
Having the same issue, full tank of gas standard transmission, and no check engine light. Will die going down the road and also while sitting idle. Almost like it runs out of gas, replaced fuel filter then the pump still no luck. Having it put on the dagnostic computer on monday,
any ideas?
Friday, August 19th, 2011 AT 1:07 PM
DOCFIXIT
  • 18,828 POSTS
When it dies does it start right up? If no pull plug wire check for spark if good spray carb cleaner into intake crank
Friday, August 19th, 2011 AT 9:11 PM
EDINGMAN
At times it does others it takes a few mins need to get a can of carb cleaner to try that but still gets spark (or at least did yesterday when we tried that) brother said spark was an orangeish color.
Saturday, August 20th, 2011 AT 9:07 AM
DOCFIXIT
  • 18,828 POSTS
Maybe bad coil spark needs to be blue/white
Saturday, August 20th, 2011 AT 7:48 PM
EDINGMAN
Yea I got that (same thing brother said) and I would be inclined to go with that if the "periods" were somewhat consistant. But it takes fits of sorts where it will die 5 times in a mile then decide to run right for the next 50. Should I even have it hooked up on the diagnostic computer at the dealership on monday like its scheduled (no check engine light)
Sunday, August 21st, 2011 AT 3:27 AM
DOCFIXIT
  • 18,828 POSTS
I would go with coil if no lightthe diagnostic may not reveal anything
Sunday, August 21st, 2011 AT 7:14 PM
