abs light is on
40,000 MILES • 6 CYL • 2WD • MANUAL
RICHARD BRINSON
I just put rotors, pads and bearings in the front of this ranger and it is doing some funky stuff. When I start it, the brakes are hard and the abs light is on. I drive it and the brakes then become normal and the light shuts off. after just a little while the abs light will come on and the brakes will feel normal. However, if I were to shut the truck off and start it up again, then it does the same thing. It will do this over and over again.
Oct 10, 2008 at 7:24 AM
BMRFIXIT
  • 19,053 POSTS
Lets run the codes to see whats going on you may have a brake booster going out. These videos will help you get the codes and fix the problem.
https://youtu.be/Pb6nXV-iamI
and
https://youtu.be/rTtAnsOlZU4
Apr 27, 2021 at 3:21 AM
