wiring diagram for stereo
T-N-T
I'm installing a new stereo in my ford ranger and i have a list of what wire is for what. However some of the wires are not the same colors as what is on my list. can you give me a list of what each wire goes to and if the color of the wire could be a different color what it would be. i need it from the side of the truck not the new stereo . thank you
Mar 6, 2009 at 2:36 PM
PITON3853
I tried to copy the image, but it was too low of a resolution, please email me the picture. piton3853@gmail.com
Also, I am trying to locate the Parking Light Relay. It is not in the Smart Junction Box or the Fuse Box under the hood. Any ideas on its actual location?
I did check those, thanks for the heads up though...sometimes it's the simplest things that mess everything up. I am looking at the wiring diagram in the Haynes manual and it shows a Parking Lamp Relay that is between fuse 3 and the Main Light Switch. This relay seems to affect every problem I'm having, but I can't seem to physically identify the relay in the truck. Any thoughts?
Thanks.
Apr 10, 2010 at 7:02 AM
BLUELIGHTNIN6
  • 16,542 POSTS
I see it in my wiring diagram as well and it's showing it as being located in the smart junction box which is behind the right side of dash.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1998.jpg
Apr 11, 2010 at 11:19 AM
PITON3853
Right, I saw that as well. The only problem is, that after extensively looking at what I think is the Smart Junction Box (the fuse box in the lower right kick plate of the cab of the truck under the passenger's feet) I have discovered I do not know what I am looking for. If the Smart Junction Box (SJB) is in a location other than that fuse box in the cab I do not know where it is. Can you help me understand what I am looking for? I do not see anything that resembles the relays in the fuse box under the hood. Thanks.
Apr 12, 2010 at 12:08 PM
MICHAEL B. HERRICK SR.
I'm upgrading my 04 ranger xlt's speakers and would also like a readable image sent to me of the wiring schematics. Thank you. michaelbherrick@gmail.com
Jun 5, 2017 at 1:05 PM
  • 55,562 POSTS
There are a few different radios so I have included all of the radio wiring diagrams for all of the systems. (below)
Cheers, Ken
Jun 8, 2017 at 4:49 AM
