2004 Ford Ranger tune up problems
2004 FORD RANGER
300,000 MILES • 6 CYL • 2WD • MANUAL
COWBOY4HIRE79
i just did a tuneup on my fathers service truck, and the origiol wire routing made it sound like crap, the wire diagram told me i had it all wrong. so i switched it to it, made it sound worse, tried to put it back to origiona configuration, but ahd 2 wires switched, sounded better but no power, what can i do?
Oct 29, 2010 at 7:39 AM
WRENCHTECH
  • 20,761 POSTS
Which engine is it?
Oct 29, 2010 at 7:41 AM
COWBOY4HIRE79
3.o
Oct 29, 2010 at 7:43 AM
WRENCHTECH
  • 20,761 POSTS
https://images.2carpros.com/forum/automotive_pictures/561653_Firing_order_04_Ranger_30_1.jpg
Oct 29, 2010 at 7:45 AM
COWBOY4HIRE79
thats the wire diagram i have, which made it sound worse
Oct 29, 2010 at 7:46 AM
WRENCHTECH
  • 20,761 POSTS
I assure you that is the right one. You may have cracked a plug or something.
Oct 29, 2010 at 7:47 AM
COWBOY4HIRE79
checked and inspected all the plugs today. last night i had to replace one because it was cracked. and broke....
Oct 29, 2010 at 7:48 AM
WRENCHTECH
  • 20,761 POSTS
I don't know what you want me to tell you. The truck ran good, you changed the plugs and maybe wires and now it doesn't. Something you did caused it. I gave you the firing order. Go back and double check everything. Make sure none of the wires are damaged.
Oct 29, 2010 at 7:53 AM
