2004 Ford Ranger Stalling
138,500 MILES • 6 CYL • 2WD • AUTOMATIC
TALBERT
I have a Ford Ranger 04 and the problem is that with the A/C on when you put the truck in gear it tends to stall. With the A/C off it will not do it as much. I just changed the IAC sensor but it still does the same thing.
Sep 16, 2010 at 8:34 AM
WRENCHTECH
  • 20,758 POSTS
First check for any vacuum leaks and then try cleaning the throttle body.
Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle.
Jan 3, 2020 at 7:37 AM
