2004 Ford Ranger slave cylinder
80,000 MILES • 6 CYL • 2WD • MANUAL
FRED HARRISON
need to know how to change slave cylinder
Dec 21, 2008 at 9:15 AM
DAVE H
  • 13,383 POSTS
Slave Cylinder
Removal
Remove the transmission. For additional information, refer to MANUAL TRANSAXLE/TRANSMISSION .
NOTE:Inspect the clutch housing for traces of fluid. If brake fluid is visible, install a new clutch slave cylinder.
Remove the clutch slave cylinder.
Remove the bolts.
Fig. 17: Removing Clutch Slave Cylinder
Courtesy of FORD MOTOR CO.
Inspect the clutch slave cylinder for the following:
Worn or damaged boot.
Leaking fluid.
Worn or damaged bearing.
Inspect the clutch release bearing as follows:
Rotate the outer race while applying pressure. If the bearing rotation is rough, install a new clutch slave cylinder.
Inspect for wear or damage.
Installation
To install, reverse the removal procedure.
Position the clutch slave cylinder to the transmission and install the bolts.
Fig. 18: Positioning Clutch Slave Cylinder To Transmission
Install the transmission. For additional information, refer to MANUAL TRANSAXLE/TRANSMISSION .
Dec 21, 2008 at 2:01 PM
